Cooling Sys, Fuel Pump Resistor, etc 12
, 16-04-2018 at 01:14 PM (1775 Views)
Koyo Racing Rad nicely installed.
Please do not change the position of the hose clamp and the angle of the hose against the neck.
These were done on purposely based on the design of the Koyo rad and the same for all owners using this radiator.
Polished the coolant pipes as there were many corrosion around them.
The most time consuming task of replacing just the two hoses at the eng oil cooler.
The pipe holder bracket was already cracked and the pipe was just hanging in there….
Missing bolt and sensor harness holder.
Cracked TB lower cover….
There were so much debris, sticky gunk, etc behind the oil cooler body, base bracket.
Spent ages removing and cleaning.
Liquid gasket at the thread of two upper bolts.
