Brake OH, DR shaft, etc 15
, 01-03-2018 at 03:14 PM (2299 Views)
Although I tested the GROM USB3 device with JDM spec head unit, didn't try it with European spec one so time to do so.
Ancient iPod Mini and the memory stick (you will need creating specific directory name and structure).
For the Android device, it requires the installation of Dashlinq App and looking at the required permission,
I didn't like allowing the access to some of the area of my phone so didn't test it.
However, from the feedback from other owners, should work fine.
Again, as my personal view, it's not something I would be encouraged to replace my existing
USA Spec PA11-HON for my specific usage but if you don't have anything at the moment and
looking for something, very strong candidate.
The owner wanted disabling the illumination dim control on the Clock and the CCU display so made the necessary modifications.
Details here;
http://www.nsxcb.co.uk/entry.php?700-Clock
http://www.nsxcb.co.uk/entry.php?770-CCU-Illumination
http://www.nsxcb.co.uk/entry.php?775...llumination-02
http://www.nsxcb.co.uk/entry.php?838...llumination-03
After reviewing the installation options and the very likely usage with the owner, decided to drill the hole at the bottom of the centre arm rest box.
As GROM USB cable uses well-made shielded type with lock mechanism at the plug side, I had to make the hole bit wider than what I normally use for
the PA11-HON so the grommet is bit loose but does the job.
