Eng Refresh + LMA, etc 53
, 29-05-2017 at 02:52 PM (3179 Views)
The weatherproof sheet was nearly completely destroyed and allowing moisture to get in contact with the door card as well as the forward section of the speaker box.
The screws for the door handle were not OEM and later I found them at the speaker box.
There are only four of them used at the door handle when you need five for the speaker box so obviously, missing one.
Will apply quick repair for the sheet as there is no point in restoring it and should be replaced with new one next time.
Bit out of focus but always apply compound to prevent terminal corrosion at the non-WPC connector behind the door card.
Honda should have used WPC type.....
At the passenger footwell bass speaker, someone wrote some numbers on the speaker box.
Not sure what that means… Just full of dust so not great working on it….
