Brake OH, Cooling Sys, etc 33
, 26-10-2016 at 09:37 PM (4280 Views)
The A/C CCU Cabin temperature sensor (aspirator fan).
Quite surprised that it didn’t make that annoying noise at certain angle/temperature with
all these debris built up inside the impeller shaft.
Adjusted the shaft holder position and no more noise.
Should have done it at the first place.
What all these extra wires are …..
Anyway, this is where I install the adaptor loom for the USA Spec PA11-HON.
From the breakout point behind the left side seat to the centre channel here.
You can connect the adaptor loom directly at the back of the head unit but I prefer behind the left side seat so that
if I want to make any changes in the future, it can be done without removing the head unit.
By enlarging the existing hole at the centre arm rest box and creating suitable hole and
the grommet at the aluminium base plate, the controller is now installed.
On my NSX, I installed the Apple device in the upper compartment.
However, I don’t know what kind of device the owner is going to use so for now, I’ll just leave it here.
As mentioned, I’m not an audio guru but to my ears and taste, when OEM Alpine head unit and
the Bose speaker + AMP are operating perfectly, the sound quality is good enough when used with PA11-HON
despite the fact that the source music file is the compressed lower quality.
Quick check of controlling the Apple device through the OEM head unit.
