Brake OH, Cooling Sys, etc 31
, 24-10-2016 at 09:57 AM (2469 Views)
2nd round of pressure bleeding.
No bubbles came out so not required but considering the structure of the rear brake piston, I always prefer doing this.
Brake pads and discs were re-used so I prefer setting the fluid level to here and not to the max line to show it’s not new.
Just set at the lower side of the triangle of the arrow.
Old Main Relay re-soldered, coated and to be returned to the owner for an emergency spare.
Please keep it somewhere on the car so that it can be used for yourself as well as for another owner.
Already some of the owners in Japan and US are experiencing the 2nd Main Relay failure on their NSX that
they replaced long time ago.
Probably they used the previous batch of the replacement Main Relay before the manufacture increased the amount of solder used.
Collected the JDM spec wiper blades for driver and passenger side from my local Honda dealer.
Unlike UK spec, it comes with the spoiler at the driver side and of course, it won’t scratch the back side of the bonnet/hood.
It’s 550mm compared to the UK spec of 500mm so if you need replacing just the rubber blade in the future,
please order 76622-SZ3-003 (about GBP9 each!! although it’s graphite coated) or
the aftermarket one with suitable rubber block shape and the length.
However, if the price doesn’t change, quite often, you are better off replacing the entire wiper bladed again because
the whole bits are only about GBP13 and it’s cheaper to order in UK than Japan for some reason.
76620-SL0-309: Driver side for RHD model, GBP12.58 at the time of writing
76630-SL0-309: Passenger side for RH model, GBP13.00 at the time of writing
Not sure why the driver side is cheaper when it has extra spoiler compared to the much simple passenger one….
As always, real black is the key for the appearance of any cars.
New wheel arch liner and with the a/c condenser fan cover at the FR side.
The later spec one with extra clearance against the wheel so bit of trimming required but it's already marked on the liner itself so easy task.
