Cooling Sys, Health Check, etc 36
, 27-07-2016 at 12:41 PM (2799 Views)
Keep cleaning…..
Before/After.
With limited space available yet so important to set the trans seal at specific depth/angle, I always use SST for installing this seal.
Installed.
Left side drive shaft. Before/After.
And installed.
Will tighten the suspension bush bolts/nuts under 1G later.
What a dirty fuel trapped inside the old fuel filter.
Because of the white balance effect due to the reflection from the grey floor, it may look light brown but it was more like dark brown/black colour.
New fuel filter installed.
Quick fireup to check the ATF seal and driveshaft movement.
No warning lights.
