ABS Check
, 16-05-2016 at 02:56 PM (2471 Views)
Just received another latest ABS modulator for the upgrade purpose.
As my standard procedure for any new modulators delivered at my place, checked it using my NSX as there were several faulty units reported in the past.
Power up the modulator by turning the IG key into P2 On position and confirmed that the ABS light switches itself Off after a few seconds.
At least, this unit is fine.
ABS upgrade loom from T3TEC in Japan.
Once again, thank you to Mr Toyoizumi for the continued support.
Modified the SCS terminal as I don’t like using non-WPC spec connector and also better to be able to use the paper clip method rather than asking the owner to find jumper wire.
Configured the wire connections to suit the owner's NSX spec.
The owner is going to sort out the installation by himself so hope he will see this and collect the parts from my place.
