ABS Upgrade, Door Window Refresh, etc 09
, 08-06-2015 at 03:24 PM (1708 Views)
Spent long-long hours cleaning the area and finally, I’m happy with the result……
Before/after.
I was so tired that I wanted to change the rhythm and didn't want working on the left door….
Decided to recover the windshield washer system.
Convert this back to OEM spec dark black tube with OEM motor and tank.
I didn’t like using these old one way valve with rattling ball inside so decided to replace them with the spring loaded check valve ones.
The tube holder was broken so replaced it as well.
Although the owner kept most of the original tube, one of them was missing so created one from my spare. It’s OEM so same colour as the original ones.
