Defrost panel, Bilstein damper, iPod adaptor 04
, 19-06-2014 at 11:22 PM (3224 Views)
While the seats are out, good opportunity to clean the carpet. I found several changes there.
Someone already removed the seat in the past and instead of unlocking the cable tie, decided to chop off the fixing that the cable tie was doing nothing.
One of the main cause for damaging the cable while operating the slide switch.
Steering dropped and we can see the shock absorber feature protecting the driver in case the unfortunate happens.
As mentioned many times, because of this design, whenever you get in and out of the cockpit, never ever grab on the steering to support your body. 100% guaranteed to damage the mechanism and you will always get a few mm side way movement at the steering. If it gets worse, the play will increase to like 5mm and that will be really annoying and even dangerous while driving.
New and old defrost panel.
