Eng Refresh 18
, 08-03-2014 at 12:37 PM (2774 Views)
New thermostat installed.
Looks so much better after washing the TH body.
Before/after shots.
The saddle of CL release fork was quite dry so applied Urea grease to
prevent heavy pedal feeling as well as the squeaking noise.
New CL slave cyl installed.
I have seen many people claiming that they installed it from the top by
removing the air box.
While it is possible, I have no idea how they can install the slave cyl spigot
into the release fork saddle properly and most importantly, no idea how they
can check the seating of the rubber dust cover.
The owner brought the aftermarket CL hose with adaptor so installed them
together with new bolts before placing the engine back in the bay.
