Testing the Latest ABS modulator
, 30-12-2010 at 12:17 PM (24279 Views)
From time to time, the accuracy and the reliability of new parts are not up to one’s expectation. For example, there has been some failed units reported on the latest ABS modulator even from new.
Therefore, it is always important to test it before the installation.
You don’t want to install and upgrade to the latest ABS only to find the failure at the control board…
So, before the installation, I always check the ABS modulator using the same electrical connections on my NSX as I already upgraded my ABS to the latest spec.
The logic of ABS warning light has changed for the latest model and thus, it is a good way to check the new module.
This one worked fine and ready for the installation. Just need to wait for the arrival of ABS upgrade loom from KSP Engineering...
