ABS Upgrade (non-NSX), Health Check 11
by
, 06-01-2019 at 12:28 PM (2422 Views)
Already tested using my NSX and really didn't want introducing air into the master cyl tandem piston so just a quick ABS reset.
It's SSR so unlike the ordinary mechanical relay, no clicking sound.
Short two blinking ABS light at the end so confirmed the ABS reset sequence. Good.
By the way, new GND cable installed for the test.
So much better than the twisted and partially damaged old one.
FCU re-soldered and coated.
Now need tidying up the ABS loom inside the cabin and then bleed the brake system.
Keep pushing….
