For some reason, the Eng GND cable was not connected and tucked away behind the coolant header tank. The coolant level was fine but the header tank was really old and already turned ...
Based on the recent Health Check Service, started to work on another NSX. The service menu is something like this; Replace cracked Header tank and unknown condition of the coolantReplace Main RelayErase old TCS error codeReplace damaged TB tensioner bolt sealRe-install Front valve cover properly As it takes some time to drain the old coolant, started with the cooling system service. ...
With the age and the heat, the coolant header tank will turn into dark yellow colour over the years and sooner or later, it will start to crack around the middle section where the upper and lower sections were glued together. Also, you may see the crack around the neck area where the cap sits. I normally recommend the owners to replace the tank once you can’t see the coolant level even with the LED light applied behind ...
Good call to replace the header tank. It was already cracked and leaking the coolant. The coolant hoses were also didn't feel healthy so at the time of TB/WP service, it would be best to replace all of them. You can replace the header tank without loosing too much coolant but I always bleed the air afterwards ...
After replacing the Crank Pulley on one NSX yesterday, another owner visited my place in the evening to leave his NSX at my place. Today, I'm working on it. The menu is to replace its Crank Pulley, Coolant header tank/cap and the yellow clips at the windshield lower molding. Long time ago, when I worked on this NSX, I had to remove the widshield lower molding. At that time, I had limited spare yellow clips and ...
