View RSS Feed
All Blog Entries
  1. Final Touch 04
    by , 08-01-2015 at 10:41 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    Didn't like the state of the boot lid height alignment so removed the non-OEM spacers and adjusted it as much as possible.
    Updated 10-01-2015 at 01:00 AM by Kaz-kzukNA1
    Categories
    Body
  2. Eng Refresh 20
    by , 20-01-2014 at 02:34 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
  3. Eng Refresh 24
    by , 17-09-2013 at 10:17 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    After cleaning the inside of valve cover, always replace the
    valve cover gasket, dust seal and IG coil hole seal as a set.
    If you order the proper kit, it also contains the metal/rubber disc washers
    that must be replaced every time when the fixing nuts were removed.
  4. Final Touch
    by , 20-05-2013 at 10:37 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
    After bleeding the brake,
    went out for the test driving session.
    This is the first time I used SoS LMA so paid
    extra attention at lower rpm range although
    the test pipe and back box were so loud that
    it eliminated almost all of the sound above 1,500rpm.
    SoS LMA sounded bit different at idle rpm but probably
    that’s just my ear as I knew it’s not exactly the same one
    as the latest OEM one.
    Happy with the
  5. Eng Refresh Stage 1 + LMA (SoS) – 15
    by , 14-05-2013 at 10:37 PM (Today at Atelier Kaz - ex-Honda R&D, F1, Indy/CART engineer)
