Pressure bled the brake. Silicone grease on the IG coil cover gasket. ...
Tow hook cover was missing from the front bumper so new colour coded one ordered and installed. Hope it will stay there for longer this time. Most of the time, it will come off if the bumper was re-sprayed or with the age and heat, the rate of warping between the bumper and the hook cover is different resulting in cover ...
Started the flushing service on the classic ABS and as soon as I opened the bleeder plug, I knew it’s going to take long time. Nothing came out from the accumulator...... Not a single drip...... So the accumulator was completely empty. Manually activated the ABS pump and immediately, I found the cause of the ...
I’ve already completed short distance multiple test driving sessions before going out for the long run so doing another catch up updating the blog....... After all these weeks, by now, the bottom section of the radiator should be dry. However, after so many fire up, I noticed this at the right bottom ...
