New RR wheel speed sensor and installed. Applied silicone compound around the sensor body and hub carrier hole in order to prevent future oxidation. ...
Updated 20-12-2014 at 01:34 PM by Kaz-kzukNA1 (defined blog category)
Cut off the ...
Before/after of cleaning the intake manifold entry. It was that dirty.... ...
Another place with high oil pressure that can cause oil seepage. The oil press sender unit. Replaced the o-ring and should be fine for many years. As reported earlier, the IG coil harness holder ...
Just keep buidling the engine in preparation for the installation. New two coolant hoses at the oil cooler. The rust around the hose was fairly thick but the other side was fine so for now, ...
