I've only had a quick look so far, but changing the headlight bulb does not look an easy job! Any hints or tips on how to go about it?
I also wondered about this, very good point.
Open the bonnet, unscrew the black plastic cover, change bulb, screw black plastic cover back in place, close bonnet.
Test using the switch by the right of the steering wheel to make sure you have tightened everything up properly.
Use a torch to look at how everything goes in first, you need small hands.
it's not hard - I did it in the carpark outside halfords without tools or even having researched the method.
pretty much the same as most other cars, and in fact easier than some I've had before.
Darren Ferneyhough
http://today.nsedreams.com
Working with a growing team improving health, wealth & prosperity.
If you know someone that wants or needs to improve any of these
areas please connect them with me via my LinkedIn profile above
:lol: :lol: Would you believe I trained as a mechanic in a previous life too! Changed my front pads in under 30mins last week, but haven't looked at how to change a bl00dy headlamp bulb! I'll check it tonight.
....the side lights however are a pain in the rear to change.
Advance warning..... sometimes it is a nightmare trying to line the black cap up right.Have patience.
it is much much easier to do the job when the lights are DOWN rather than raised ( took me bloody hours to figure that out first time I did the job! :oops: )
"Organ transplants are best left to the professionals"
