There are lots of same relay used on our NSX.
As you have already upgraded the ABS and if you know the electronics system of it, you could use some of the same relays no longer in use.
In order to prevent any corrosion to the terminals at the relay socket, it is always best to keep something inserted there so it can be only a temporary solution.
As you already placed the order, it is the best thing to do.
Good luck with the test driving session and please remember to clear the error code first before you start driving.
