Now then.
I’ve owned my NSX for a couple of months now and just haven’t been able to get comfortable in it.
I’m quite a big fella (6’4” and about 16st), not ‘all legs’ and so headroom has been a real issue for me. It seemed OK on the test drive but I suppose I was excited about the car and busy trying to assess its condition, so it didn’t really hit me as a problem.
However on the long-ish drive home, and then on another couple of long trips in it (3 hours or so) I found that my head was very close to the roof, and I was tensing my shoulders to pull my head downwards away from the roof. Not good.
I could adjust the seat to make it a bit better, but this resulted in bizarre positions with bent/splayed legs, weird body angles and extended arms. Not really ideal for enjoying the car.
I looked at various options, including the Dali seat cushion, a pair of Recaro PPs, the Downforce seats, the SOS rails etc, but they all seemed less than ideal and/or very expensive.
As part of my research, I tried the standard seat without the cushion, and found that it transformed the seating position for me. One friend suggested a moulded custom cushion (like they use in single seaters), another offered an old camping foam mat, and soon a plan was formed.
The plan was to create a moulded seat base to replace the OEM item using two-pack expanding foam, tidy it up and then get it trimmed in black leather to match the rest of the interior.
The moulding is done by mixing two liquids together, putting the mixture into a bin liner and then sitting on it while it moulds and then sets.
With the OEM cushion already removed, I taped around the edges to stop the mould finding its way into the crevices under the side bolsters:
Then protected the interior with polythene sheet, again taped to stop it moving around
Bin liner in place, to check it was big enough to contain the foam
Two-pack foam ready for mixing
