It's probably too much caster on at least one side. That's something I've got to get sorted (seized adjusters), but braking deeper into left-hand turns gets round it for now.
Another thing that makes it worse is cross-toe at the rear; it creates a thrust angle & makes the car more oversteery one way than t'other. That might be your problem if initial turn-in seems consistent.
I'd recommend a good alignment (an often relatively inexpensive 'fix') if you otherwise like the car & see where you go from there...
Nick
