TB on the shelf argument
Please remind that the TB on the shelf is not working at all. So the shelf argument is not correct.
Rubber parts have already been mentioned. Even if not using the car at all rubber seals get pressed, old and leaky. This is for example the case for the clutch hydraulics, injectors, A/C and so on.
Garage queen NSXs don't need a high amount of repairs, actually less than one that is driven BUT the £ per miles relation is very high if you don't drive it often, just because the repairs can't be divided through more miles.
I know of a completely new car still waiting for a buyer and it ran into all specific problems an NSX reveals over time like all electronic related problems. As soon as you start to drive the car you should be prepared for repairs or change the common parts in advance.
It all depends if the molecular chains within the oil become fractured. Our trucks used to go 100Km between oil changes. Samples were taken at this time of changing and the oil was still in relatively good condition.
They were working 24/7 and covering 4-5000km per week, so I accept that cold starting can lead to more engine wear as the oil has time to drain away when stood, but i doubt the oil itself has deteriorated.
And in case your wondering out of 100 trucks we had only one major engine failure in 4 years, and that was a manufacturing defect.
John
2004 3.2 Man, Formula Red. Now Sold and not missed as much as expected. Life goes on.
Hi and good to hear from another owner.
I've only just spotted this thread and noted your question had gone un-anaswered. It may now have been addressed in the other thread, but for completeness, I would without hesiitation recommend you discuss your requirements for maintenance with Kaz. You can contact him through the Health Check thread.
I look forward to meeting you and seeing your original low mieage NSX.
Paul
Fascinating stuff - which makes of truck do you run?
VTEC apparently can be quite hard on oil; they seem to dirty it quickly at higher mileages (hydrocarbon by-products blowing by the rings, I have read) which means I often give the cars an interim change, despite ridiculously low mileages.
Thanks all. It begs to be used today - I'm home early but guess what - it's throwing it down!!!
Interesting! Pleased to see the trucks still have it, even in the cars' FREDs have been annoyingly unreliable - until recently anyway. I suppose anyone can make a mistake; Porsche cannot apparently machine an RMS recess consistently and late-model S2000 engines started exploding.
[QUOTE=markc;74652]Good quality modern engine oil will easily last and provide proper protection for a year almost regardless of how/where the car is kept. Unless you do big mileage changing the oil every year or 12k miles is quite sufficient.
Just out of interest, why do you need to change the oil every year if it hasn't done the 12K miles? Does it deteriorate with time?
Andy
