Right, I finally got my NSX back from Plans on Friday. Amongst other things, it had a replacement clutch, and I'm not sure that all is right. However, since I've only ever driven one NSX properly, I can't be sure whether this is a problem with the car, or the symptoms of a new clutch yet to bed in, or something they all do, or just my inexperience with the NSX's clutch?
* When pulling away, the clutch judders quite a lot, to the extent that the car sometimes seems almost reluctant to move away. This can be minimised with higher revs, but I'm trying not to slip the clutch at all.
* When manoeuvring (therefore at lower revs) it's even worse - the juddering can be almost violent.
* Occasionally, moving away is accompanied by a popping sound (a bit like the stone pops you get when driving on gravel). This can also sometimes happen when coming on/off the accelerator when crawling in first (as in traffic)
Thoughts? The car, or me?
And is there anyone around Heathrow with a manual NA1 with whom I could meet to compare?
