Results 1 to 2 of 2
Thread: Climate Control Unit
    Default Climate Control Unit
    Hey, my climate control unit does not seem to be functiong properly at the moment:
    1. the display does not work
    2. the fan only seems to come on at the maximum setting, but not the intermediate, more gentle air flow.
    Has anyone got any suggestions? Presumably, i'll need to have the unit replaced or repaired?
    vic
    Jun 2003
    If you're sure you haven't got it on the wrong setting, like full auto, where the unit controls the fan speed then there may be something wrong.
    There is a known problem with the capacitors failing in the speed control circuits and the fan runs on full. It is a fixable problem, I don't have the details, but they are on www.nsxprime.com if you can find them.
    There is a diagnostic mode too.
    - Set Fan to Auto.
    - Push and hold both MODE and AUTO while you start the engine
    This runs through all settings.
