My brake story, maybe the info will help.
I bought the car with OK/good Honda discs. Nice and smooth, a little worn, no juddering, braked nicely. I took the car to our annual mountain run in France. After I learned the car, I started to push it and the brakes started to fade. I could make them fade on the downhill runs. The brakes started to judder. By then the fluid had probably boiled too so I bled them as best I could considering we were on holiday… Tyres are S03s so softish.
At home I checked the discs, they are warped (usually caused by too much heat). The calipers are ok, they seem to work equally.
I saw the prices of Honda discs, had to sit down. So I ordered cheap ones (and an extra set too) from some place in Britain (£27 each? Or £19. I forget now).
After thoroughly changing the fluid with new normal fluid, I took it to the mountains and the same thing happened. But not any worse than with the Honda discs.
I checked with the garage that serviced the car before I bought it, they fit only Honda stuff so I assume the first set of discs were Honda (is there a stamp or something so I can check?). The pads are Honda stock.
So my conclusion is that the discs are too small for the weight of the car under extreme use. Actually in my opinion, ANY car’s brakes are too small for extreme use, the Cosworth ones ended up in the bin so fast it was a blur. Absolutely useless. With the NSX, it’s not so bad, though, they are not absolutely useless, just a little under sized. And I still enjoy the car a lot, I haven’t even made the time to install the big disc set yet! So it’s not THAT bad. Just my experience.
Peter
'88 Daihatsu Charade GTti: 993cc, 3 cyl, what's your excuse?
'92 Cosworth Escort 340hp
Lotus 26R S2 (under construction)
'78 Escort MkII rally car
an ugly white van
and I left the best for last
'91 NSX
