Will my wheels fit?
This are brand new and were intended for my 300zx. I believe the fitment is the same however i was going to get a ABflug Beet kit which is wide so my wheels have a big offset.
Blitz Type 03
front
235/40/18x9 et35
rear
295/35/18x10 et22
In the end i got my 300 arches rolled and flared but they didnt come out too well and the arches did not match up both sides however they did cover the wheels.
The Honda has a different mounting bore front and back, check the size[s] for your Datsun.
As for the offsets, assuming comparison between OEM 16" and 17"
FRONT
You will proably need a 5mm spacer to regain OEM clearance with the inner wheel arch; whether they clear the brakes who knows, with a 5mm spacer they will be some 50mm proud of the OEM outer face
REAR
Inner clearance is safe, the outer will be some 40mm proud of the OEM outer face
- You may not post replies
- You may not edit your posts
Forum Rules
