Looks like a typical Honda Camber (sic) adjuster. They always seize onto the internal shaft, because Honda is too tight to lube them with Copper grease at the factory. I've a seized OSR on the S2000. We get round it by torturing the rubber bush, but I cannot dial in as much camber as I'd really like.
Now that's all steel/cast iron. Yours is a steel caster adjuster in an ally casting. Just add water and you've got electrolytic corrosion.
What I'd try is drowning the bugger in Plus Gas almost daily for a couple of weeks before the next alignment. With luck, it may soak in and you can break the corrosion with a club hammer. Good luck - it can cost £3,000 in new lower wishbones on an S2000, if they are all seized!
Nick
