Just in case anyone is thinking about buying one.......mine melted in the heat from the sun.
It's a sticky gloopy mess. any tips on how to clean it off appreciated.
Formula Red and Black 3.0 manual
If you can't clean it off I think you should cover the dash in Alcantara....
Good luck though.
the only thing I can think of would be white spirit or something along those lines.
HTH
A hairdryer (medium heat rather than high) and white spirit or WD40 maybe?
1999 3.2 Manual 6 Spd Coupe
Honda's Finest Hour
.....have you tried contacting the company that makes then? Seems like a schoolboy error on the design front. Might be able to get them to suggest a suitable cleaning fluid, and compensate you for your trouble maybe....
If only I'd kept the packaging, I would hae written to the manufacturer and sent the photos. Doh! Never thought I would need it at the time. I can't even remember who it was.
Have managed to get it off quite well using White and Methylated spirit alternatively. Thanks for the suggestions.
Lesson learned - Dont use non-slip mats or remember to remove from the dashboard every time.
