Does anybody have detailed instructions ( workshop manual extract or technical service bulletin ) regarding the hole driling required to fit a new design water pump into the old shell?
"Organ transplants are best left to the professionals"
once you have your new pump in place, just offer up your cover in the correct position and the drain pipe will touch the cover in the place where you need to make a hole for it to go through - if you slap a blob of grease or something onto the pipe then it will show you where to drill, select a suitable sized drill bit and you should be pretty much there.
Darren Ferneyhough
http://today.nsedreams.com
Working with a growing team improving health, wealth & prosperity.
If you know someone that wants or needs to improve any of these
areas please connect them with me via my LinkedIn profile above
Don't know if it will help, but see my post, about halfway down.
http://nsxcb.co.uk/forum/viewtopic.p...ght=water+pump
'88 Daihatsu Charade GTti: 993cc, 3 cyl, what's your excuse?
'92 Cosworth Escort 340hp
Lotus 26R S2 (under construction)
'78 Escort MkII rally car
an ugly white van
and I left the best for last
'91 NSX
