Yes, you're right. The Dept of Transport says that, according to the letter of a law coined 20 years ago and therefore before HID/Xenon headlights were in existence, they are not legal unless fitted on a new car or in a total headlight replacement scenario:
http://www.dft.gov.uk/pgr/roadsafety/drs/hidheadlamps
New vehicles with xenons get exemption from this ruling because they have European type approval, so (the logic goes), the only way to get aftermarked HID lights would be if the entire headlight was changed and replaced with one which itself had type approval.
EU legislation says that new cars with Xenons must have self-levelling suspension or the lights need to self-level, and they must have some form of headlamp cleaning.
I asked Dan from DTA about MoT pass/fail with his kit, and he said he's never had a customer have a problem at MoT time because of having the kit. Passing an MoT and being legal aren't the same thing, mind...
Anyway, the legality issue has been covered before - http://www.nsxcb.co.uk/testvb/showth...ansport&page=4 - and I'm guessing no-one on the forum who's been running an HID kit for the last couple of years, has been nailed for it...
ex owner - various Hondas inc 03 NFR NSX-T
Current fun car Lotus Evora 400
Hi there great write up, but why have you got to file it? I got a slimm digital set from SAW on Prime, and the bulb was a perfect fit. I got the 6K kit into OEM NA2-R lamps.
AR
thank Ary - I did try the bulb against the aperture before filing, and it looked like it would fit but would have scraped down the side of the bulb - I figured taking 1mm off wouldn't do any harm and the bulb could go through without touching the sides.
Maybe the 02+ aperture is slightly larger than the popups, though it does look pretty much the same as the diagram in the instructions.
cheers, Ewan
Hi Ewan,
Thanks so much for your superb write-up! I'm glad you are pleased with the upgrade
Just to answer a few questions that were asked further up in this thread:
(1) Light colour (temp) vs output: It is indeed true that the HID bulbs with the most light output are 4300K bulbs. The HID conversion kits I sell are all 6000K (4300K is optional) and this is a very happy compromise between light output and colour. You are absolutely right in saying that he Saxo/MaxPower brigade choose 8000K+ kits because of the blue/purple "look". What they fail to notice (probably because it is a bit "dim" everywhere) is that light output drops as the colour temperature goes up. I've had people phone up asking for a 12,000K kit and I will always refuse to sell that as a candle would probably put out more light!
(2) Red/Black/White wiring: All pop-up headlights have red (+) and white (-) headlight wiring whereas fixed headlights use red (+) and black (-) wiring. All our HID kits utilise red/black wiring so that should take the guess work out of the installation procedure. Furthermore, Honda uses two different size spade connectors (5.0mm and 6.3mm) in their headlight wiring loom. Initially our HID kits came with spade connectors of only one size (6.3mm) and I normally include a (home-made) conversion lead to overcome this problem. However, our current bulb supplier ships bulbs with the correct size spade connectors so there is (a) no need for a conversion lead and (b) the kit can only be wired up ONE WAY thereby eliminating any chance of getting it wrong. By the way, if you install a HID kit "the wrong way round" it won't blow a fuse/ballast/bulb - it simply won't ignite and start up.
(3) Increasing the size of the bulb holder aperture: The reason for this is that (at least with all our kits) the HID bulb is of a larger diameter than the standard halogen bulb. As was said above, the HID bulb will probably squeeze through the existing aperture but it "could" damage the bulb. Therefore I recommend you increase the diameter of the cutout by approx. 1mm by using either a rounded metal file or dremel. Make sure you don't get any metal filing in the headlight enclosure (not a disaster if you do but it just makes for a neater looking headlight). There are some HID bulbs out there which are slightly smaller in diameter but ours are definitely not.
(4) Headlight adjustment/MOT/Legality: It is IMPARATIVE that you check and adjust the headlight alignment AFTER you've installed a HID kit. Because the HID bulb is longer than the standard halogen bulb the focus of the light is in a slightly different part of the headlight. This causes the lens to focus the light higher which in turn could dazzle on coming traffic. Any garage/MOT station will check and adjust the alignment for a token payment (usually no more than £5/£10).
I have been selling these kits for over 3 years now and not a single customer has ever had a problem with passing an MOT. I too use these kits on my own cars and have never had a problem. I know what you're thinking, he's saying that because he sells the kits but I guarantee you that it has never been brought to my attention that an MOT failure was due to the installation of one of our HID kits.
Legally speaking, yes - these aftermaket kits are illegal because retrofitting a HID kit into what is originally a halogen based headlight will invalidate the E-mark of the headlight. That is technically the only reason why it is illegal. However, reality is somewhat different in that if your headlights are properly aligned and you're not sporting blue/purple 8000K+ headlights it is extremely difficult to tell whether the headlights are OEM or aftermarket. Headlight washers are only mentioned as requirements because dirty headlight will scatter the light more than clean ones. This is more prevalent with Xenon headlights than halogen ones.
The beauty of our kits is that the installation is completely reversible. Should you be required to remove the kit for whatever reason you can easily pop the original halogen bulbs back in and off you go! 10 minute job if that ...
Apologies for turning this into an essay but I think it is always useful to give all the information at hand. That way owners/customers can make informed decisions.
Should anyone have any further questions please feel free to contact me.
All the best,
Dan
MD - DTA-Motorsport (UK)
T: 0845 4744-382
E: info@dta-motorsport.co.uk
I've been doing a bit of reading on the pros/cons of fitting HID upgrade kits - most (if not all) people who have them will sing their praises, and everyone who sells them will tell you good they are.
If you're sitting on the fence, there are a few sites which paint a different picture - about how the type of light from any HID is *technically* not as good as Halogen in some cases, how the headlamps designed for Halogen are not optically suitable for Xenon bulbs etc etc.
http://www.danielsternlighting.com/t...nversions.html
http://hid.moonfruit.com/#/beam/4529652061
On a slightly different note, I notice that you installed the ballasts on the wheel arch. When I installed mine I put them upright behind the light assembly with double sided tape. There's probably not a lot of difference, but it just looks a little neater.
James.
I am Godzilla, you are Japan!
This is indeed true. Although not generally advertised you should generally NEVER install HID's if the headlight is of the reflector type. Retro fitting HIDs is only really viable when installing in a projector type headlight. I do have some HID bulbs (H4) which have been specifically designed to be used in reflector situations but they are very expensive (treble the normal HID bulb price).
