hi all
I bought an HID upgrade kit from Dan at DTA, and thought I'd document & take some pics of the install since Dan's excellent instructions are based on a pop up model.
In practice, the install is easier on the fixed car since you don't need to take the whole headlight out. I decided to keep the screw-on dust caps at the back of the headlight unit, but there was no problems of access. [I put new bulbs - Osram Nightbreakers - into my Accord estate, and it has exactly the same light unit by the look of things, but much more fiddly]
Firstly, unscrew the cover at the back of the dipped headlight and remove the two connectors from the bulb and the assembly.
Take the bulb out then twist the light grey connector which is attached to the body just below the headlight.
Press the tab nearest to the headlight to free the connector from its bracket, then pull the connector apart.
Now the wiring from the old bulb is free, it's easier to do all the connecting to the HID bulb away from the car, rather than fitting the HID bulb first then plugging everything together.
Carefully cut the old grommet off the OLD bulb connectors [it wouldn't do any harm to leave it on, I suppose].
I made a hole in the middle of the new HID's grommet
then took the silicone covers off the old bulb's connectors then (carefully, with long nosed pliers) pushed them through the grommet, then reattached the silicone covers and attached the Red wire's to the corresponding Red connector from the HID unit, and the same for the Black connector to the Black connector on the HID unit. [Dan's instructions had Black/Red and Red/White, obviously the wiring on the pop up cars being different].
I didn't have a small enough file to make the aperture in the headlight assembly any larger, but a Dremel & vacuum cleaner did the trick. The Dremel was also used to enlarge the existing 20mm grommet hole in the middle of the headlight cover, to around 25mm.
All the wiring for the HID bulb passed through the headlight cover easily, grommet pushed into place and the installation took minutes from there. I tucked the ballast just behind the headlight and stuck it using the double-sided sticky pad.
So far, I'm very pleased - the HIDs and LED sidelights should make the car look sharper, as well as giving a better beam!
