The Bradi discs should be good. Dali uses them for the slotted discs. I not sure but I think Brembo may use Bradi discs for some of their kits. After all how many foundries can there be making discs for every type of car out there? I would imagine there are a few foundries and the rest of these 'performance' discs are plain discs that have been machined.
Be aware Mintex don't keep the rear pads in stock in 1155 compound anymore. Don't know about 1144. You will have to have a batch made. I am thinking it, let me know if you want that compound.
The brake kit I am doing will use a new front caliper and disc, and a new disc with moved orginal rear caliper. So the rears will still need OEM sized pads.
