Hi Adrian,
Can’t help so far, but a while ago I had what sounded like a stone or something in my brakes. It sounded exactly like that, hope it was. The sound came from the rear right side. I stopped and then went on, it was gone. And there where no stones or gravel around anywhere. It was the strangest noise. (It was not the ABS noise from the front, that’s a distinctly different noise). Later I looked, and couldn’t see how a stone could have made that noise for that long (10 metres). And there are no scratches anywhere on the disc etc. Does that sound like your noise?
Just lately I notice a “loose nut” sound while driving on cobbles. Seems to be coming from the front.
And just lately, the ABS has been cycling quite often. The ABS problem is documented quite a lot on NSXprime so I’ll have to look at that one day (or just unplug the ABS…).
So if anyone has had the same sort of noises, please give us your thoughts.
About the “loose nut” sound, I had a similar noise on my Escort, it was the little bracket that holds the hydraulic brake line to the shock absorber body. But not so this time.
peter
'88 Daihatsu Charade GTti: 993cc, 3 cyl, what's your excuse?
'92 Cosworth Escort 340hp
Lotus 26R S2 (under construction)
'78 Escort MkII rally car
an ugly white van
and I left the best for last
'91 NSX
