Dear All,
I have read that there are issue's with the ABS system on the NSX if the cars are stored and not used regularly I was wondering if this could be reduced by using DOT 5.1 Silicon brake fluid, or are there any issue's with this on the NSX?
If the fluid is drained and replaced with new DOT 5.1 silicone fluid, will the ABS modulator also need to be bleed?
All comments welcome.
