Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: 'H' stickers for centre cap
  1. Default 'H' stickers for centre cap
    Hi everyone,
    Does anyone know where I could buy the 'H' sticker that goes in the middle of the centre cap on the original Honda Alloys?
    I have tried looking everywhere and nobody sells them.
    Andy
    If you're struggling then I can get them made for you if they are the same as mine .... What color?
    HTH, Paul
Name:	Japfest Wheel.jpg
  3. Default Thank you
    Thanks for the offer....i am going to try a friend that works for an etching company first....to see if it is possible to do it that way.....he can use stainless steel to cut the 'H' out and then i think we will spray them red i guess and stick them in. I need to create an accurate template for him to etch though so see what happens
    How do you make them up though? What metal would be best to use and what sort of paint is best? What sort of costs would it be if you were to create them?
    I am currently in the process on revamp the wheels.....I have the calipers painted red with the 'nsx' in white...the alloys have been refurbished to a matt black finish...so i am looking to make the 'H' red so that they compliment the calipers.
    My car is still with the mechanics so once I get it back I will post a photo of the newly refurbished alloys on the car....cant wait to see how they look
    Cheers for your help
    Andy
    stainless etch/cut i can understand if you want it shiny, but seems pointless if you are going to paint them... can't you just go to your nearest vinyl cut sticker shop, say you want a honda badge to fit in a circle x diameter, and pick your colour? or am i missing something?
  5. Default
    Wicked wheels tried vinyl and two different thicknesses of aluminium all cut and perfectly shaped in aluminium.
    These were one off orders from their contact and every attempt failed! Reasons were too flimsy and with the thicker grade of alu it just didn;t sit right when it was dropped in.
    They ended up painting the Hs by hand.
    Good luck!
    Luke
    2004 54 red/red manual
    Quote autocar Nov 2005
  6. Default here is the alloy
    Here is a photo please bear in mind that this was before the refurb as they look a little knackered.....
    Lankstarr: 'Wicked wheels tried vinyl and two different thicknesses of aluminium all cut and perfectly shaped in aluminium.'-
    yeah i was speaking to a friend that has a laser cutting machine but he cant do metal but plastics....so thought best to go with metal.
    I will see how the metal etching goes.....but i guess i should go quite thin i guess but not too thin that they become flimsy.....i guess i will try to experiment and then post a photo if i am successful
    Any ideas what adhesive would be suitable for trying to stick it to the alloy? i keep thinking if i am driving they may fly off at motorway speed and become some sort of mini shrieken!!
    Andy
  7. Default
    Andy,
    Have you tried Honda themselves?
    I 'made' some custom Honda caps for my Work wheels - this involved buying new metal adhesive H logos (you don't have to worry about them coming off - the adhesive is VERY strong) ...
    Check out ... http://daliracing.com/v666-5/info/ho...y-center-caps/ ... MJ liked them so much he stuck it in his DIY section ;-)
    The part no for the H logo was 44734-SR3-900 ... if you give the first 5 digits to a Honda dealer they may come up with some different sized ones (i.e. Xmm in height) .. might be worth a shot.
    Regards
    Paul
    ... I've just measured the spare one I have in the shed ... top to bottom is 38 mm ... top corner of the H to top corner is 34 mm ... bottom corner to bottom corner is 29 mm ...
    attached a pic
    They also do one 34 mm top to bottom ... 44734-SR3-H00
    and one 36 mm top to bottom ... 44734-SR3-000
    - assume other dimensions are proportional
    Paul
    1997 3.2 NSX-T : Ext. Magnum Grey : Int. Red / Black
  8. Default Thanks for the advice people
    Cheers I will try and have a look at the number with Honda. I have already cut out templates for the etching thing...so I will see how my mates turns out the etched cuttings.....lets see what happens and will keep you posted.
    Thanks again
    Andy
    Jun 2005
    Worcestershire
    Just as an extra to this thread I have a vinyl cutting machine and am happy to knock out a few H's as I also have the correct logo as an .ai file and .eps if anyone wants..
    Further to this does anyone have any thoughts about nsxcb.co.uk stickers for our cars I could do - Leigh and I chatted about it a few weeks ago and I wondered if there was any interest?
  10. Default Hi
    I would really appreciate it if you could send me the .eps file. I spent cutting out about 14 different shapes lol and still not as accurate as i would like.
    Maybe i could make it more accurate and see what happens with my mates etching technique.
    Even though i have not been in this forum or club for very long I have had alot of helpful advice and would feel proud to have an NSXCB sticker on my car it would definitely beat having the 'car dealers name' on the back windscreen
    Thanks again 'TheQuietOne'.
    Andy
