Results 1 to 3 of 3
Thread: Window fix it thingies
    Default Window fix it thingies
    Just installed the window fix it thingies cost $20 for 2 from Dali - Started using the windows again after 6 months of avoidance.
    The easy install method given on Dali's website is spot on. Took me 40mins the 1st side and 30 mins the 2nd once I new how all the fixings hang together.
    Jun 2003
    Did you use the 'super EZ install'? Guess who supplied that one! Actually it worked fine for the drivers side, not so easy for the passenger side. The cables on the passenger side seemed tighter than the drivers side.
    Yes your right - I used the super EZ method. The only things to add is that:-
    I ended up cutting slices of the plastic thingy with a stanley knife to get the first cable end out. This took a certain amount of conviction that the replacement was 100%.
    The window slipped a bit even with it taped up. Pushing the window up by hand from the base of the glass gave me that extra 1mm to ease the cable in to the new part.
    Any how kudos to you for supplying the instructions.
