Page 1 of 5 123 ... LastLast
Results 1 to 10 of 362
Thread: Tyres
    Jun 2003
    Default Tyres
    I've put together these links to help in the finding of tyres for the NSX for various years.
    1991 - 1993
    Front 205/50ZR15
    Rear 225/50ZR16
    1994 - 2001
    Front 215/45ZR16
    Rear 245/40ZR17
    2002 - 2005
    Front 215/40ZR17
    Rear 255/40ZR17
    The tyres that are listed is not going to be an exhaustive list, and even though some tyres are listed may not be available.
    Nice one Kev, thanks
    Great idea Kevin! Will be very useful, especially for new members!
    1999 3.2 Manual 6 Spd Coupe
    Honda's Finest Hour
    On the rear with 17", how wide can the tyre be? I have 255/40/17 Toyo T1R which are running low. Can I go up to 265/40/17?
    I am running 225/45/16 up front.
    This is the tyre size calculator I use.
    http://www.miata.net/garage/tirecalc.html
    Check and see if it is still within 5% of the OEM rolling circumference difference.
    ****1997 3.2 Orange / Black SOLD****
    Previously driven by.........
    Jeremy Clarkson, Tim Harvey, Richard Burns (RIP), Jason Plato, Harvey Postlethwaite (RIP), Manfred Wollgarten, Dirk Schoysman, Barrie Williams.
    Nurburgring lap time 8:38 - Honda NSX (sport auto, 08/97)
    Jun 2003
    This is the one I use;
    http://www.alloywheels.com/tyrecalc.asp
    Use the recommended width calucator to see if those 265 will fit on the rim designed for 245.
    Quote Originally Posted by Kevin View Post
    1991 - 1993
    Front 205/50ZR15
    Rear 225/50ZR16
    1994 - 2001
    Front 215/45ZR16
    Rear 245/40ZR17
    2002 - 2005
    Front 215/40ZR17
    Rear 255/40ZR17
    Do we know the recommended pressure for all these tyres, or are they all the same for the different sizes?
    Thanks
    Feb 2004
    Tavira, Portugal & Wexford, Ireland
    Currently running 215/40/17 upfront & 265/35/18 outback on a '95 targa without any TCS or ABS problem, and well tested at track too.. Using Kumho MX which have been great on track and reasonably priced.....
    Ciaran
    Quote Originally Posted by madras View Post
    Thanks
    I have always been told to use the same .... however, if someone know different, ie by checking their manuals? please let us know.
    regards,
    Just had 255 40 17 GY F1 GSD3s rear tyres fitted, they stated their guide for that particular tyre & size, recommends 33 PSI, but when I questioned this, they stated this is only advisory!? My previous oem 245 BS RE010 was 40 PSI, but I know when you go wider, it normally means less PSI is required. Is 33 psi about right guys for those with GY 255s or any other 255 tyre brands? Cheers
    Honda's Finest Hour
