Apparently according to the dyno Paul's NSX lost power with the Dali Apexi filter. The OEM is near perfect.
As Kevin stated, on top of the 3.2 manifolds, you will need adapters, test pipes or cats, and a back box.
So the 3.0 Aftermarket headers will work out cheaper as cats are very expensive.
AR
[quote=AR;36346]Apparently according to the dyno Paul's NSX lost power with the Dali Apexi filter. The OEM is near perfect.
Got IT TAITECH 3.0l Headers - With Cats = +20 hp or test pipes ((Barry ? / Dirk ? ) do they work for the same company? V-Tec direct)).
I have the Procar CF intake airbox and associated intake scoop which houses the conical Apexi filter.
Does it add power ... maybe. As I've said previously in other threads, what this system did do was to smooth out the overall performance and allowed all to breath well.
Dyno day performance was a success for me as my NSX produced the best BHP results on the day.
One added benefit for me over other systems available is how good it looks inthe engine bay.
HTH, regards Paul
The Honda Racing guys here in Germany installed that system at their 3.2l
engine in combination with headers and exhaust.
The difference was 12 HP+ at the dyno with that Procar intake system
Our NSX was dynoed with 301 HP without and 312 HP with that system,
not sure if thats a power increase.
The airbox is bigger than standard (+28%), the dry APEXI filter is the best one at the market.
This is the system.
http://nsxcb.co.uk/testvb/attachment...3&d=1189320388
Years before we produced some airboxes for Daliand the super succer boig gulp, which he named it at his webside.
Years later he tried to fix that APEXI filter into the standard airbox.
This will not work, we tested it.
+12 hp?! Should this mean that the OEM air intake is the bottle-neck? Actually I don't believe this +12 hp. Is there an explanation for this?
