Hi, If anyone has a standard speaker for this near side door. Please give me a shout. Cheers in advance Steve
Is yours broken or missing??
Hi, I replaced the right door and the left foot base speaker. But my speakers are screaming. Not even sure if this is the problem now!. My drivers door speaker was getting very weak before it all just started screaming. So I thought replacing this would fix. The only item I don't have is the left hand speaker. If I had them all I could get them checked out and amps fixed before replacing them. Any help? Cheers in advance Steve
Most likely the amps. Any decent tv repair man will be able to check them out. The capacitors usually start leaking over the circut board and short circut the tracks. Soldering in new caps will cure it.
Need more info to really diagnose.
Does this happen on the radio and the tape player and the CD?
Does the screaming noise come from all speakers or just one?
