welcome to the NSX ABS pump, the loudest pump on the world! yes, it's under the bonnet.... On mine it sounds like you are running over a metal bucket, and dragging it down the road! in fact when it first happened, I stopped and got out to find the bucket! fortunately it doesn't happen that often, but usually goes off just as you are driving past someone who was, until the noise, giving the car admiring looks!
if you find somewhere slippery and 'exercise' the abs the pump will kick in and at least you can then identify the abs noise!
PS... unlike other abs systems, where the pump activates when the abs activates, the NSX system pre-charges itself, so when abs is needed, it doesn't have to wait for a pump to kick in before working!
