Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 84
Thread: Common Faults
    Glad you posted that Mr S. My flap is just starting to stick a bit...
    OEM spring is P\N: 74494-SL0-000 in case anyone wants to know.
    Jun 2003
    Chexbres, Switzerland
    Don't think the headlight switch is a 'common' failure.
    12. Main relay - dry solder joints - can be replaced or repaired.
    13. Unlucky for some - getting to the stage of having to sell it
    I think this one counts.
    Rear brake light bulb blowing and triggering the TCS and ABS lights. Replace bulb and then no problem!
  5. #15
    don't forget boot and engine cover gas struts that loose their effectiveness...
  6. #16
    ....that little fan in the centre console by the ash tray that gets noisy after a while....
  7. #17
    Default Wobbly stereo volume control
    fixit on NSX Prime US tech forum
    "Organ transplants are best left to the professionals"
  8. #18
    Is that a fan? I thought it was the interior temperature guage! That siad, my fans above the stereo are annoyingly rattly!
    Steve.
    __________________________
    Jaffa - 1991 Black on Red Manual - SOLD
    2001 Landy Discovery 2 TD5 - BOUGHT
  9. Default
    Quote Originally Posted by Steveycaz View Post
    ha ha - thought I was the only one with rattly fans!
    Mine stopped through some miracle recently
    Add to soln to REAR LIGHT CONDENSATION - silica gel behind boot trim
    15.736 - COOLANT THERMOSTAT also seems to have affected a few of us, symptom = car taking a long time to warm up.
    who can be bothered to put the list all together nice and neatly then?
    L*
    2004 54 red/red manual
    Quote autocar Nov 2005
  10. #20
    1. Internal door habdle break, - new fix it thingy from Dali fitted.
    2. Snap ring - new casing available, but I opted to fit new snap ring, from HUK (£3.50).
    3. Slow windows, - re-grease runners?
    4. pop-up head light wobble - Tighten securing nuts via wheel arch.
    5. Window regulators- plastic clip breaks - replace with Dali fixits
    6. Speaker amps break - replace capacitors
    7. Condensation in the rear light clusters - remove and drill a few small holes underneath.
    8. Crank pulley failure on early cars irrespective of mileage. Age related failure. This will become more common over time it seems. £466 HUK
    9. A/C HEATER UNIT - New caps required on pcb.
    10. N/S wheel sensor = ABS/TCS lights.
    11. O2 sensor = ECL and oftren TCS lights.
    12. TCS Light - CEL code 3-4 (VRef Signal) - This usually relates to the main relay located on the rear bulkhead (near the TCS ECU). Either resolder the joints on the circuit board of the relay or replace the relay itself. This tends to affect early model cars.
    13. Petrol Filler Flap not opening properly - Check\replace the small black (metal) spring near the hinge. Sometimes you can bend this back to make it more 'springy', P\N: 74494-SL0-000
    14. Rear brake light bulb blowing and triggering the TCS and ABS lights - Replace bulb and then no problem!
    15. Boot and engine cover gas struts that loose their effectiveness - refurb or new.
    16. That little fan in the centre console by the ash tray that gets noisy after a while - take apart and clean.
