SS,
I'm sure someone more technical than I will chip in, but essentially what you are looking to do is allow the gasses to flow IN and OUT as freely as possible.
The sound can be tuned if your exhaust provider is skilled enough, so there is no need to have a socially unacceptable exhaust unless you want it. AYK, Kevin has fabricated some inserts to control db's, proving you can have power and less noise.
Mine had the exhaust only for a while, however it wasn't until I changed the inlet side with the airbox and scoop that everything settled down, was smoother and more free revving. Noise levels on mine are close to OEM around town and cruising, but much more interesting and exotic sounding when playing
The question to ask yourself is 'do I want more performance or just a cosmetic improvement?' Answer this and you will know whether to install a system or simply change the OEM tips.
HTH
Regards, Paul
PS - just remembered ... aren't you canging the headers to 3.2's? If yes then you will probably opt for a system. If going this route it may be worth asking H&S how much to install headers at the same time as a new tail section.
