Results 1 to 2 of 2
Thread: NSX-R anti roll bars
    Default NSX-R anti roll bars
    I know this has been discussed a long time go, but I cannot find the thread.
    Anyway, I had a couple of questions;
    1. What is the best combination front rear for fast road use.
    2. Is there any difference between the na1r and na2r front anti roll bars?
    I seemed to remember someone saying the type-r front and type S rear was the best option.
    Cheers.
    I am Godzilla, you are Japan!
    A good combination for fast road use is the front Type R / rear Type S swaybar but it also depends on the suspension. I don't think it works great with the OEM springs/shocks unless you run the Type S or Type R suspension. The Type R swaybar can be a little bit too much, esp. under too late and hard braking as it can heavily and suddenly understeer. A little bit less stiffer might be better.
