Results 1 to 3 of 3
Thread: E10 fuel
    Nov 2008
    Weston super Mare
    Default E10 fuel
    Sorry if this has been covered. Just wondering what mods if any we have to do to use E10 fuel?
    Jan 2018
    Near Stuttgart, Germany
    Since these mixtures have been in use in the USA for along time before coming to Europe, the NSX should be fine.
    Gasoline Containing Alcohol
    To increase the octane rating, some gasoline companies blend alcohol with their gasoline. They normally use either ethanol (ethyl or grain alcohol) or methanol (methyl or wood alcohol). You can use a gasoline/alcohol blend in your car if its octane rating is 91 or higher. However, you should check its contents carefully first.
    Gasoline blended with ethanol is sometimes marketed as gasohol. You can use gasohol in your car if it contains no more than 10% ethanol by volume.
    From the 1991 owner's manual
    Heineken's Garage
    No mods required for the factory spec NSX to run E10 fuel ...
    https://check-vehicle-compatibility-...facturer/Honda
