Results 1 to 8 of 8
Thread: Rockauto 5% discount code
    Default Rockauto 5% discount code
    [Edit: 11/May/22] New code: 174850639159405243 same as last year.
    Expires on 10/JUL/22 Midnight CT US
    [Edit: 26/May/21] New code: 174850639159405243
    Expires on 25/JUL/21 Midnight CT US.
    Rockauto 5% discount code: 167144841152619337
    Expires on 09/May.
    You can find lots of similar code on the web and by sharing this, I won't get anything but hope it will save a little for someone on here.
    Rockauto states that one can share the code freely and can be used many times so please feel free to use it.
    New 5% discount code: 135665687125742427
    Expires end of May 2020
    So is this for real ??? Drive shafts for around a tenth of the price of Amayama ? Are they any good, has anyone bought any ?
Name:	1991 ACURA NSX 3.0L V6 CV Axle | RockAuto.pdf
    They are just aftermarket, not refurbished OEM, a different spider design I believe. They are OK though from what I've read.
    Mmmm..... interesting. I'm thinking that for the mileage my car does (4k per year) these might be good enough. I'm not a great fan of aftermarket pattern parts but maybe worth further investigation.
    There were mixed feedback.
    OEM one uses roller slider design for both the inboard and outboard joints.
    You need to be very careful with the chassis setup such as the rideheight and the alignment.
    Extreme setup will damage the joint as there is a limit on angle due to its design.
    With the aftermarket one, most likely they are using the conventional ball bearing coupling joint.
    I don't know the design spec but some would show noticeable play even when new.
    The ones (probably the same company but used to be called as Surtrack) I installed years ago didn’t have any play.
    Later, some owners bought the same drive shaft (but possibly under new brand name???) and that was when I started hearing the small play.
    On NSX Prime, among the FI application owners, Insaneshafts seemed to be popular.
    Don't know the design spec but looked to be using ring bearing (or whatever its called) and again, mixed feedback as well.
    Seems to be good customer support if there was a problem but that was years ago so don't know the latest.
    Another code: 174850639159405243
    I'll add this in the OP as well.
    New code received but same as above: 174850639159405243
    Expires on 10/JUL/22 Midnight CT US.
    Please enter the discount code in the 'How Did You Hear About Us?' box without any other numbers or characters.
    I'm not related to Rockauto and won't get anything for sharing the code.
