Results 1 to 6 of 6
Thread: AC Compressor
    Default AC Compressor
    Just replaced my AC Compressor with a new one. I'm sure the old one is serviceable if you are that way inclined. Came off a 1992 car. Might be good for the pulley or clutch mechanism if nothing else. Seems wrong to just bin it.
    Free to whoever wants to collect it from Crawley.
    OEM or aftermarket?
    R134a spec?
    Unless someone needs it urgently, would love to collect it although most likely going to be next year....
    As far as I know it is the original Denso compressor fitted to the car. R12 spec.
    I would also like to have/collect this to refurbish it as mine is already squealing and giving me trouble if Kaz is Ok..Otherwise will leave to kaz as he replied first.
    Hi, SS.
    No problem and please discuss it with NSXGB.
    I'm only after the clutch/pulley/coil assy and not the compressor body itself.
    And even that is the 2nd backup option as ideally, I want to find the 97+ spec offset assy.
    After your overhaul, if you happen to still have spare CL/pulley/coil assy, I'll appreciate if you can keep it for me until some point next year.
    I'm after Denso 471-1193 compressor that has the 97+ spec offset but unfortunately, it's been out of stock at Rockauto for months.
    I already have one 471-1193 for one owner but need another one next year for another owner and just looking into backup options.
    Hope you are fine considering your working environment.
    Thanks Kaz
    keeping safe and all well ...so far.
