Next up is refit the number plate lights….. however….
IMG_20200408_163634 by jon sutherland, on Flickr
Yes, minging, and not sure they actually gave out any light!!!
Lenses taken off, after cutting a slit into the screw to actually undo it….
IMG_20200408_164249 by jon sutherland, on Flickr
Cleaned and stuck back together, the one already broken broke into 3, the other, already cracked broke too when they were washed!
IMG_20200408_171601 by jon sutherland, on Flickr
Better, but still needed to be attacked with a dremel to polish the last of the grime inside!
Holders cleaned up ok, the rust scraped off and rust treated….. I did have to spend some time reconstructing the internal shield, as they had got a bit fragile and crumbly over the years!
IMG_20200408_171554 by jon sutherland, on Flickr
Somewhat better now!
2020-04-09_09-09-36 by jon sutherland, on Flickr
I do have new brackets coming, as they are available and not too silly priced! still £12.86 each delivered, but better than hours fettling in the garage!
