Results 1 to 10 of 14
Thread: Assembly process for door mirrors
    Default Assembly process for door mirrors
    Help needed please ...
    I want to put my door mirrors back together ... but for the life of me cannot recall how I managed to extract the inner working parts from the outer body ... and needless to say, no matter what I am currently trying, it is very much square peg round hole as they refuse to allow me to reconnect the two parts ...
    I hope one of you nice, knowledgeable owners can offer some wisdom on how to achieve reassembly .. or maybe you can provide a link to an online manual??
    Many Thanks in advance, Paul
    Aug 2009
    Hi, Paul.
    Not sure you wanted to know how the actuator housing (custard/yellow) meets the back of the mirror plate or
    how the [mirror+actuator] assy sits inside the painted outer housing but I presumed it was the latter and
    hope these photos would assist you....
    Thanks for the feedback and links gents ...
    The issue I have is the reinstallation of the mirror plate inside the painted outer housing. I recall when stripping them thy were difficult to separate, so not surprised reassembly is a challenge ... I’m sure there’s a knack one of you will know. Pleeeaaaassssee
    main mounting hardware into housing?
    motor assembly onto the glass?
    or the glass/motor assembly into housing???
    just to clarify....
    After you have connected both sides of the electric cable and place with plastic leading pin to the mirror housing holder spring, this picture will help you to find the right
    hand position to press the mirror holder incl glass carefully to the mirror housing.
Name:	Spiegelglas einsetzen 1.jpg
    Best position to do this is if the parts are laying on the table.
    Than you take the mirror assembly and hold it like into the mounting position.........this picture from KAZ is very helpful (as usual) and shows the next step.
    If that job is done, you can press the mirror glass at the top side inside the mirror housing.
    Now you can see and check the small metal holder, he should be hold the mirror/actuator assy.
    Carbonfiber parts 'Made in Germany' + NSX-R parts specialist
    emails to Procar Specials directly: send email
    Procar Specials NSX-RR details here
    Pictures from Procar Specials parts here
    Dyno video watch here
    just to clarify....
    Clarified ... how to get the black INSIDE the red ... Thanx
    Dooh!!!!!!
    Looking again at the last photo from Kaz (copied above) and it shows the housing slightly turned as if partly towards folded position... so I’m wondering if this is the key because if I rotate through 90’ as if folded, this reveals two Philips screws.
    Looking at this, I’m wondering if this facilitates separation of the upper body of the mounting plate from the base. This I’m thinking would then allow my to feed the plate inside of the body and then reconnect to the two parts?
    There is as can be seen in the photo, a fairly meaty looking spring, so before I attempt the separation, is there a risk I wont be able to put it back together without specialist tools??
    Thanks again ...
  10. Default
    Best advice is to turn the top part of the side mirror ~ 90° to the window before you remove that complete unit from the door.
    Than you have best access to the 2 golden Philips screws, which holds the upper part (see picture)
    I have done many of my cf side mirror conversions, sometimes you have to drill out that screws, because they stick like hell into the chassis, even with the 'right' tool.
    I replace that damaged screws with Allen screw with lens head (V2A stainless steel)and use some urea grease during installation.
    You will never have such a problem again.
    No. If the small metal holder at the buttom side is removed, you can carefully pull the glass outside the chassis.
    Maybe the white pin will spring out of the chassis mount, but it can be easliy pressed in again.
