Results 1 to 6 of 6
Thread: Heater fan
  1. Default Heater fan
    Hi Guys
    After being in South Africa for a while am back here and time to get the old girl out for the summer !
    But ......
    To my horror, i have a problem with the heater fan control, the blower only works when the knob is set to max, any suggestions would be much appreciated.
    N5
    Sounds like it could be the common capacitor leakage problem in the climate control unit....
  3. Default
    THANKS
    Probably dealer only ?
    Quote Originally Posted by djwrays View Post
    THANKS
    NO!!! Definitely not a dealer.
    Kaz offers a second to none repair economic service.
    A dealer would probably recommend a new CCU, approx £3,000
    Either Kaz or BrianK here in the States.
    http://nsxe-repair.com/Climate.html
    1994 Formula Red | Advan RGIII | AD08 R | Stoptech BBK | GT-One N1 exhaust | NSXCA #3863
    Jan 2018
    Near Stuttgart, Germany
    Very likely the CCU capacitors. I replaced all capacitors with dry type before they started leaking and it's not exactly a DIY job, indeed. A professional electronics repair shop familiar with the NSX is therefore a good recommendation.
    If you're at it, maybe you can ask the company who is going to perform the repair whether they could also service your three Bose active speakers and the radio too. These are very likely to fail around the same time and due to the same reason (leaky capacitors).
    Heineken's Garage
