Results 1 to 10 of 34
Thread: Replacement battery advice
    Default Replacement battery advice
    Hello.
    My battery has died totally during storage even whilst on a Ctek charger. I wasn’t prepared for this and need to move it on Wednesday. I’ve had a look on the forum and seen
    31500-SV2-001HE-SV2-001HEmentioned as the original replacement (mines a manual 3.0) and to buy direct from Honda.
    Is this still the correct part and do you think I’d be able to get one for Wednesday if I order it tomorrow.
    If not, can anyone give me the detail of a currently available alternative I’d be able to get quickly.
    Many thanks
    Phil
    no doubt people will disagree, but the lead acid battery tech pretty much hasn't changed for a car since the car began!
    so as long as it's 005L spec, just buy one from the shop that has it in stock as you are in a rush!!!! local motor factor, battery specialist, or halfords (if you are desperate....) most come with a 3 year guarantee anyway
    not recommending this, just a quick google search example that shows the critical bits, the basic size and the terminal layout
    https://www.tayna.co.uk/car-batteries/enduroline/005l/
    I'm happy to recommend Tayna, I've bought batteries from them, cheaper than Halfords and delivered to your door.
    Last battery change for the NSX was from a Honda dealer, price OK [Honda Happiness?] and with excellent forum recommendations.
    I went for the battery for an Auto [though mine's a manual] as it fits and has a greater capacity.
    Hi Jonathan
    When you say just buy one, do you mean to just trust the equivalent they suggest ? I’m concerned I’d end up something that wouldn’t fit
    Aug 2009
    As long as the battery physically fits, has the same terminal configuration as the OEM one, and has the same Voltage (!), & at least the same CCA, RC & AH ratings as the current OEM one, then it will be fine.
    I have bought a Bosch SM Mega Power Silver battery for my daily driver, but there isn't an NSX-sized battery available.
    In the UK Halfords will get the battery to the store of your choosing next day if not in stock already.
    Thanks to Prides generous offer (and the backup offered by Kaz) my car is now working again.
    Thank you forum members.
    Cheers Phil, no problem.
    Just to say that if your NSX isn't used as a daily then I'd strongly suggest getting yourself a CTEK MX5 digital pulse battery charger which incorporates a fully automatic battery conditioner, so there's no need to keep having to remember to turn it on and off.
    Hi Philboo, I've got in my garage a brand new unused Honda NSX battery which you can have for just £60+p&p guaranteed next day delivery (Tuesday)or free pick up from me which ever you prefer.
    PM me if interested.
    ah, i forgot the epic Pride battery saga!!!!
    everyone suggests the 005L as that's the battery size that matches oem sizing/layout/spec.... i'm sure if you went to honda and got the battery, whoever the manufacturer is that actually makes it will list it un-honda-branded as a 005L battery
    they are all a muchness, tho you can find them with a slightly higher Ah, and CCA ratings....... but as supply and demand (more delivery time) is against you, its a case of who has got what!
    Sounds great. I’ll send you a message
