Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Tension in TB
    Not sure you have seen these photos so I'm going to post them in a hope to assist you.
    I can't provide exact weight force data against the TB but when the TB tension is properly adjusted and if applied very gentle pressure with just one finger while at #1 TDC, you will see 10mm movement from rest point in both ways like these photos.
    Good luck.
    Thanks for the comments and support.
    For my clarity: tensioning (whether blue mark or 9 teeth) is with set valve clearances so a tension against valve springs only, the plugs out so no compression from the cylinder.
    Thank you Kaz that you shared your practical knowledge. These information could be found reading the blog but here are dispelled my" doubts with 5 mm pin punches". I am during the Engine Refresh (according to your recommendations) which I Barn find in Germany.
    sorry for english i use a translator
    Thanks for all the additional info!
    One question: is the +-10mm slack at 6 right after removing the slack at 1-5 or after that?
    and please remember, only a few selected engineers were allowed to build your NSX engines.
    If I imagine the average mechanic in Europe handling that procedure who might sees an NSX every 5 years or less...at least there are no known/heard of fatal failures. So there is some safety margin in there as well.
  5. #15
    The measurement is always taken after the tension adjuster bolt locked with 9 cam teeth method and crank turned several times.
    After this, set at #1TDC and while keeping the crank locked, measurement taken.
